- Jun 28, 2010
- 1,286
- 361
- Back in New York!
- 2020
- 6.7 Cummins
I wonder if the dealer would ever be able to pull that stored message up if he ever brought it in for some kind of warranty work?
I'm pretty sure they canI wonder if the dealer would ever be able to pull that stored message up if he ever brought it in for some kind of warranty work?
Looks great, and thanks for the tip!Factory Air with adjustable links. Prob. around 7k.
Side note: Be carefully overloading the factory air, especially if you have the higher ride height. I hauled a little to much sand this weekend and blew a rear air line out of the master cylinder type component for the air suspension (idk what the parts called). Luckily it reattached without needing repair and the compressor re-inflated the system. But it sucks getting a tow home because the rear is sitting on the bump stops.
Oh yeah it handles it no problem. Through the summer I had a 1200 lb tank of water in the box a whole bunch of times. Handled like the box was empty!I was eyeing a Limited but the payload on the sticker was a joke! Glad to see these trucks can handle these weights which look to be more than what the yellow sticker says. Might have to bite the bullet after all
Go go gadget RAM?firestones.weight? don't want to know.there's 3000 lbs.of boat and trailer with it,not in the picture.
