Bdersch
- Nov 1, 2016
- 356
- 125
- 2016
- 3.6
I had a mishap with my truck. It just died while on my way to a job site. Ended up being towed to the dealer. It's under warranty. They had it for 8 days. They found a blown fuse. Said my oil was in dire need of a change(50) My recon third brake light bulb was out(70). Needed a software update(120) then they ran another test and said my battery was bad(260). They said it was good to go. Drove away. It died again probably not even 5 miles away. Called my service advisor. Told him it was dead. He said you're ******** me. I said nope. Called tow truck. They had the truck fixed by 10 am the next day. They found a bad wire which would have only cost me my 100 dollar deductible. Instead they charged me 500 something dollars in other service work that did nothing for me. He then said don't worry about your deductible or the tow bill. I picked that up. It was all I could do not to flip the counter over. They sent me the survey. I debated wether or not to even fill it out. I scored the service department the lowest I could. Wrote in the comments what had happened. Haven't heard from anyone. Don't really suspect I will either. I may not buy another truck from them. Definitely won't be buying any aftermarket warranties. Oh. I had a broken exhaust manifold bolt. The tick went away. They "fixed" it. Now it leaks all the time.
Yikes man that sounds worse than what I've got going on here! I would not have paid that money. I'd be like deductible is $100 that's all I'm paying. Hope they try to make it right. Have you talked to Ram Care on here? They helped me a ton when my other dealer was trying to hide the vibration I had and we're treating me very rudely
