Marty: I agree!
I do believe this transfer case was created for the grocery getter/Daily Comuter who sometimes needs a four-wheel-drive to help get them to and from. (those who very seldom leave the tarmac\interstate\highway/pavement). I am really curious just to see how deep of snow this transfer case would be able to handle (Non Off-Road) even though tires play a huge part in this as well.
It was definitely not created for the serious off-roader. These folks need to find a chain driven transfer case not the clutch type.
I've driven down long roads where the snow was maybe 2' deep. It handles it just fine, of course this is without the Goodyears that come on the truck. When I've been in clay/mud or needed 4-lo it wasn't an issue either.Marty: I agree!
That's what I've read on other forums. Haven't actually tested this yet. Currently I'm running Amsoil SS Multivehicle ATF in my BW 44-44 and it works fine. If you're under warranty I would recommend staying with the Mopar 44-44 fluid...So apparently dextron III ATF can be used in the 44-44 instead of the expensive mopar stuff?
Yup: Once again---->Anything that involves extend med/severe Off-Road 4WD use with this Transfer Case best be thought out.
It is what some call the (Yuppie) Transfer Case!
As long as I have No issues with On-Road driving in Snow/Ice I will have no complaints. My TC will be receiving more frequent service intervals due to the clutch style design. 2qts is a cheap service!
I know Shawn towed his 5k-lb in-closed trailer within many snow/ice storms in Utah with no complaints about this TC. He towed most of the time in 2WD but some of the time in auto. He bragged a handful of times of how flawlessly this transfer case operated especially after he drained the factory fill of ATF out.
https://youtu.be/fd3BnOEIYXY
You don't. If you don't have the Auto 4X4 button, you have the Borg Warner 44-45 part time transfer case. The front shaft is not connected via a clutch pack like the 44-44.
No the 44-45 takes ATF+4 and the 44-44 takes ridiculously expensive special fluid from the dealer.They use the same fluid right? Do they have the same "issues"
And no they do not have the same issues. The 44-45 mechanically locks the front and rear wheels together for a true 4wd. The 44-44 uses a clutch to "lock" the front and rear wheels together except when the throttle is released, the clutch disengages. When the throttle is pressed again, the rear wheels spin a few revolutions before the clutch engages again powering the front wheels. This happens even in 4Lock and 4Low.
First off, do you have the 44-45?Uh-oh... I went to the local chrysler dealer and they sold me the borg warner expensive as fluid (The blue **** i think) I wonder if thats why my truck makes a grinding sound while in engagine reverse and shifts into 4th. I have been driving it with for roughly 30k miles
Sounds like the 44-45 is much better than the 44-44, why would someone pay more for it lol
Well the good news is you have the better tcase. Congrats!I must, i only have 2wd 4 lock and 4 low, and yup
