VA10
Good morning.
Purpose of this purchase is to lower my monthly payment.
I am looking at buying a 2014 Ram 1500 Outdoorsman Crew Cab with the extended bed.
1. The build sheet says Heavy Duty front and Rear Shocks. How are these different from the standard 4x4 shocks? I think it is safe to assume it is not the air suspension - since the build sheet says shocks I would also assume it is not the coil link suspension either.....
2. do these packages/rating add anything to the truck? Or are they merely just the ratings? I cannot figure this out from the 2014 brochure or build sheet
- GVWR: 6;800 lbs
- 1400# Maximum Payload
3. the truck i am looking at has 3.92s (8 gears) vs my current tundra that has 4.30s (6 gears).
How well do these trucks tow? Intend to buy a 7k lbs + travel trailer at some point down the road. That being said how can I visually tell if this truck has all the HD engine/trans/oil coolers in it? According to the build sheet it does have the active grill shutters.
I will be trading in a 2015 Tundra Crewcab. I have 28k miles on my Tundra and the Ram I am looking at has 50k and is a certified pre-owned Ram by Ram. Should I be scared about the reliability of the Ram? My Tundra has be worry free granted it is still new. According to the carfax this Ram has had no issues - only routine maintenance has been preformed.
ANY Ramisms I need to know about before I sit and negotiate?!?! such as engine noises, rust, electrical, brake noises??????? I do not want to regret anything.
THANK YOU ALL IN ADVANCED FOR THE HELP!
- GVWR: 6;800 lbs
