EVIC oil change reset at 1000 miles?
phil g
Can the EVIC be reset if you change the oil before it is due? Is the front drive shaft the only thing that needs lubed?
2012 ram 2500 CC Hemi 4X4
quietpeen
2021 TRX
Hellcat
Yes when the message comea on I believe you turn the key to on without starting the truck and push the gas pedal down 3 times.
I know there are several threads on here that have the procedure. Check out the how to section. There are many helpful threads in there.
Also welcome to RF
