RamInfo
Ran across a couple of youtubes on using a needle attachment to grease the large ujoint on the front transaxle of the 2500/3500 trucks, and also on greasing the joint at the front of the rear driveshaft on those trucks. Are these same grease points present on the 1500 trucks? Or are there other grease points that should be hit at every oil change? And do the dealer techs automatically hit the grease points as part of a routine oil change?
Thx,
DG
Thx,
DG
