Having a problem with my lights my high beams work and my passenger low beam works. I've had hids for over a year and recently my passenger hid went out at night and my driver side was still working so I unplugged the passenger ballast and plugged it back in and it came on. Did the same for the driver side and nothing. I've put in a new ballast and bulb and still nothing. I'm getting power from the harness as I've tested with a multimeter. What else to check? Thanks. Also getting power from headlight connector with low beams on
