Help!! I just got a "low fog light fluid" message on the EVIC.. :)
baum
savage, mn
2015 Laramie
LOL :roflsquared:
Can anybody tell me what kind of bulbs the fog lights take? Since there actually is no message for fog lights do the type of bulb matter?
Thanks
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
The vertical style fogs take a 9006
The horizontal style take a 9145 which you can replace with a 9005 if you want to goto LED
B
baum
savage, mn
2015 Laramie
its a 2015 so a 9006. do they make a good bright LED that doesnt get too hot?
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
How is a bulb out on a 2015 already?
The same way that every now and then someone has a transmission fail with less than 10k on it. Had a mfg flaw, it happens. I've put on new replacement parts that were faulty and never did work.
B
baum
savage, mn
2015 Laramie
as a mechanical engineer im not one to care about if something goes wrong. parts fail its that simple. i realize 100% of vehicles are mass produced and really the only thing the manufacturer does is assembles them.
Where i do get mad is if you take it in for warranty work and it has to go in more than once for the same issue.
SIhemi
Pennslvanvia
I used a h10 LED bulb from stark. Got it from Amazon.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
I have Opt7 LED's in my heads and fogs. The H10's are hardly noticeable and I wish I would have got the 9005's.... In your case, 9006's.
Adam
SIhemi
Pennslvanvia
Adam
The h10 I used is bright. Definitely a improvement over stock.
