You need the end link rods.
The Hellwig sway bar comes just with bolts and brackets.
From Hellwig Website:
Vehicles not equipped with rear sway bar requires 7961 end link kit.
My truck came without a rear sway bar. i was planning on getting the Helwig one. What additional parts do i need to install it? oh yeah, it is stock height.
Not to hijack the tread, but if you are replacing a stock rear sway bar with an aftermarket one like the hellwig, there is no need to change the stock links, correct?
With the Hellwig, that's correct, it bolts right up. Although, I'd check the bushings on your stock links and inspect for any cracking and replace as necessary.
