Hidden features?
Power247
High Point, NC
6.4 HEMI
Damn mine must be broken. I have all my presets on XM and all the other bands set but that button doesn't do anything in my truck. Tried it earlier today after re-reading this thread.
It must be. Works the same on my '12 as it did on my '09 and on the wife's Durango.
Sent from my Nexus 7 using Tapatalk 2
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I can't find the mirrors in reverse feature so I assume I don't have it?
I have it on Laramie which I suppose back then one highest trim before the Longhorn and Limited came along so they did crazy little things like that as a bonus.
$miley
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Guess that doesn't include aftermarket remote start?
Got the windows to work with the un-lock feature. AWESOME!!!
No it does not I have both installed and it will only do that with factory installed one. When I use the Autostart or Smartstart one it just does whatever I set climate control to last.
$miley
Haserot
NE Ohio
3.6 Pentastar
Although I read my manual, this is still a great thread.
Just tried the extending visor trick yesterday. Sweet...:headbang:
Not sure if this is that secret or hidden: Your key fob has a key in it.
dmclone
dmclone
Iowa
Is there a way to turn down the brightness of the dash?
Haserot
NE Ohio
3.6 Pentastar
The horizontal dial under the headlight switch, to the right of the cargo light button. Dial to the left for dimmer, right for brighter. All the way right until it clicks turns on the cab lights.
dmclone
dmclone
Iowa
I'm an idiot. Thanks
Chewy
Bettendorf IA
V8
The mirrors going down option does nothing but infuriate me. I turned it off on our Enclave. Great, I can see the rear wheel, but I can see NOTHING else. That's a big help. NOT!
I'd like to drive mine so I can find these things. lol
VolsRam
Franklin, TN
HEMI 5.7
Is there a way to dim the dash board while you're parked with the truck running? The only way I can make them dim is to turn on the parking lights or regular lights. For example, I went to pick someone up downtown Nashville the other day and it was raining. So I left the truck running to have AC since its too hot to have nothing and raining so the windows had to be up, all while I was parked on the side of the street waiting. I didn't want to draw attention to myself by having my lights on, but when I turn them off the dash lights go as bright as ever. My Wrangler didn't do this. Do y'all know how to do it in the Ram?
Haserot
NE Ohio
3.6 Pentastar
:Rock on:
jasf
NY
I have twice now rolled down the windows & popped the moonroof in my wife's Fusion from my pocket. Glad that my truck doesn't have this "feature".
Power247
High Point, NC
6.4 HEMI
Same thing happened to me with my '09. I had a habit of starting my truck while in the office on hot summer days until one day I walked out and found the windows rolled down. It took me 30 minutes to figure out what happened. That was the last time for me.
TylerB
FL
I'm glad the window trick isn't that sensitive on my truck! I really have to try to get the windows to go down.
Sharp Charge
Brunswick Oh.
On my '12, there is a button labeled "replay" on the satellite radio screen. Not sure if it on the '13+ or not....
Also, if you hit that little star with the note button, you'll save the song to your favorites. If it plays on any channel, a notification will pop up, hit the listen button and it'll tune right to it.
chuck
Maryland
2013 True Blue Big Horn
That's one of my favorite features, I use it all the time!
Dale_K
I wish there was a hidden feature to get a digital speedometer in the EVIC on my 2012. There actually WAS a hidden feature to do just that on my old 300C. You pressed two buttons on the steering wheel and it put the EVIC into a diagnostic mode and one of the pages was a speedometer. It would even remember it after you cut off the car so that you didn't have to fool with it every time you went for a drive.
Power247
High Point, NC
6.4 HEMI
Our '12 Durango has this but my '12 RAM does not. It seems strange that it is not on the RAMS.
1Popeye
