Tangent
- Jan 10, 2016
- 263
- 263
- Montgomery, TX
- 2016
- 3.6 Pentastar
Does it actually analyse the oil or is it just a calculation of miles and idle time?
I just hit my one year mark on my 2015 sport. I only have 4k miles on it. Truck says the oil life is still good but the manual says to have the oil replaced at minimum once a year. Any suggestions?
Sent from my STV100-1 using Tapatalk
The truck is configured for conventional so anything beyond that is just a bonusI feel like the problem with going by the oil life indicator is that it doesn't know what oil you are using. We all know that dino oil, synthetic blend, and full synthetic can go different mileages. I'm currently using the dealership for oil changes(not for much longer) and running their synthetic blend. I change my oil around 6K still. The oil change indicator usually says I have between 46 and 50% life left. I'll stick to going by the mileage, no way I would run synthetic blend to 12K miles.
The DO specify the quality of oil and therefore take oil quality into account. It is called the MS-6395 spec in Chryslers case. Or Dexos for GM and API (which is much nicer to have a universal standard but I digress).
Any oil that meets that spec, synthetic or otherwise, is suitable for the the OLM. If you choose to use oil that doesn't meet that spec, you are on your own. Some people do so chasing "better" oil but you do so at your own risk.
I'm not bad-mouthing better quality oils with better additive packages but if you don't have the time or inclination to research and understand lubricants just stick to the manufacturer specifications. It isn't that hard.
And in terms of OLMs they are a better algorithm than just using one metric for oil change intervals. I expect they will improve over time just like our automobiles do but they are a definite step in the right direction to better optimize our vehicle service.
I under the MS 6395 spec, and I also have a decent understanding of lubricants and additive packages. However, if you do some research on an oil based site, like Bob is the oil guy, where lots of people post oil sample results and such, you'll see that 6 or 7K miles is all you would want to go on a dino oil, like Pennzoil in the yellow bottle. I definitely trust a synthetic blend to 7k miles, and I trust full synthetics to 10K with a good filter meant for synthetics.
