I'm a 2nd Gen guy. Here's a 2016 Ram 5500 for you.
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
Just cause I had too.
36" in the middle and 34" on the end.
Its a 2016 Quad cab 5500 Ram Cummins 4x4.
Jimmy68
Jimmy68
5.2L Magnum
more
Shark
6.4 L Hemi
You extended the frame almost 6 teet? For what purpose? What kind of turning radius you have now?
Jimmy68
Jimmy68
5.2L Magnum
I shouldve measured the wheel base. But the rear diff is 140" from the back of the cab.
Turning radius? Huge. :roflsquared:
It's getting a van body installed on it.
Fresh from the dealership to my cutting floor.
tjfdesmo
AZ
Adding another cross member or torque tube for stiffness?
Jimmy68
Jimmy68
5.2L Magnum
Adding a cross member when we build a new drive shaft. Have to install a second steady bearing. Just waiting for parts. We build our own shafts. Also adding a cross member in the back extension.
I'm only into this 14hrs so far.
This thing has four huge doors. Back ones are the same size as the fronts.
Jimmy68
Jimmy68
5.2L Magnum
Nice bit of skills there. Im sure you know what you are doing fella.
Thanks.
Yes, we have 11 guys in our shop. A Journeyman HD mechanic and an apprentice plus myself (Journeyman welder) and three "Old guys" that are welders and have been doing this for like 40 years each, another Journeyman and a few apprentice welders plus a driveline specialist who has been building drive shafts and axles for over 20 years.
I think we got this stuff figured out. Lol.
Hemifatboy
Redneck Rivera
6.4 hemi
I'm a little surprised you can't order from the factory with an extended frame , nice looking work
Jimmy68
Jimmy68
5.2L Magnum
Not that you can't but when you buy off a lot and get it changed you get it a lot sooner.
If you want a 2016 Laramie Ram 5500 4x4 crew cab Diesel and there is one on the lot, how long would it take to order one?
I can have the dealer one back to you in a week.
FXCLM5
2017 Laramie CC
ED 3.0 V6
this a fukn stretch lifted limo?
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
Interesting. Why vertical cuts and welds? Seems like most guys use either a 45* or zee cut when splicing frame rails.
lasse452
