I have a choice to make. I can either get a level kit with some new rims and tires OR I can get a tuner and an intake. I would like to get everything at once and that was my original plan however I don't want to wait anymore. I need advice!!
Look as to what I'm going to be doingSince I have a 2015 I would have to get a unlocked PCM with the tuner. IF anything went wrong I would have the original PCM to put back into the truck. Unless I am mistaken isn't that how people are getting by with warranty work?
@UNSATFC- Did you make rank this cycle???
@UNSATFC dealerships can see if a tune was put in a truck even if you restore the original pcm i believe i read it somewhere here.
OP get the level and tires in my opinion
Lift n wheels brother.
I could careless if my ram is fast.
Tuner is not about going fast. You can have it for that.
But for me it is more about having a real V8 and not the MDS V4 in my truck (except the OP has a diesel).
Thought i read that manually putting it in 8th gear instead of drive will prevent mds. Is this correct? And does putting it in tow mode do the same?
