jschwanke84
- Aug 17, 2016
- 159
- 57
- 2016
- Hemi 5.7
Of course they can be swapped.... talk to your salesman.
the newer rams have to have the computer programmed to match the mirrors it has on the truck, otherwise the mirrors may act alittle crazy (mirrors adjustments may not be correct when folded up) groing from tows to regular mirrors im not sure since thats not a very common thing for most to do. on the 3rd gen and lower rams it was literally a bolt on swap.
and how they look is all in opinion, i think some rams look off with em and some rams they look right at home on, it all just depends on the vibe of the truck, on my show truck they look goofy folded up so that only happens when i wana troll someone lol, my red truck is the only one which they run up 24/7 thats because its a hauler and flipping my mirrors between tows to appease someone is dumb and why re-adjust your mirrors all the time honestly, but also i have 4th gen tow mirrors on my 3/4 ton so that i have clearance lights so people can watch out lol
Yea, for the most part. I dont want to battle with a dealer trying to figure out sales codes and messing with multiple trips to the dealer I buy from or to one that actually knows how to use Chryslers software to get the mirrors figured out. I think im just going to forget about the Alpine setup and get a truck that has the all the other options I want, including the regular mirrors and 3.92 gears.
You do not need any programming if you swap. Our shop truck which is a 17 did the exact same thing, no issues at all. You simply just unbolt the old ones and bolt on the new ones; no programming, no nothing. If youre going the opposite direction, then yes. You need programming for the Vehicle to detect that the mirrors at flipped up so it remaps the switch buttons for moving the glass.
yes & no.....the memory has to be programmed so the computer knows if it is flipped up or not and to put it back after tilting in reverse (if set up to do so)....that can be an issue with putting tows ON since you are adding features (the up stuff).............but taking tows off and putting normal mirrors on, that feature will never be used, so it should not be a problem.
Yes it was easier in the old days to do stuff like this
where is the no, i see pretty much a yes, you basically reworded what i just said?
You would, as that's what you want to see......................I did not reword, I explained the differences and why there is a yes & no
You had said programming was required for the mirrors to act right.
I said yes & no.
yes, programming for the memory part of the mirrors to work when installing tows on a truck that came with normal mirrors because you are adding features
no, to put normal mirrors on in place of tows, you are not adding any features, but some existing features in the programming will no longer be used.
kinda like using 1 wiring harness for all model trucks....just cuz the wiring is there for cruise control in the harness on a truck without cruise control, doesn't mean it is used, or that it will get any signal.......therefore it does no harm and stops no function...but it's still there.
Programming is needed when adding features so the computer knows what is there and when to activate it, but should not be required to remove features because since the part that uses that feature no longer exists, it will never be called for in any function.
I would? Thats what i want to see?
interesting that you seem to think you know me or can assume things about me
Well, did flipping me off make ya feel any more like a man ??
I don't have to know you or anything about you or assume anything about you......but your response above tells me all I need to know and that I don't care to know any more about you than I already do.
Have you ever edited anything in your life ?? If so, you would know, if you wrote it, you can't edit it and do a good job...because you KNOW what it is supposed to say, and if words are spelled wrong, or used wrong, or even missing, your brain still sees it as you want it to be, so things get missed.
Same case here....I said something that was similar to what you said, but went farther into the explanation than you did, and your brain sees it as the same, when in fact it is not.
That is what was meant by 'you would see it that way'.
Sorry if I hurt your feelings, really didn't mean it that way.........but hey, go ahead, flip me off again.......it won't bother me at all..............
I love my tow mirrors....they are great for everyday driving whether towing or not....it did take a while to get used to them, however.
Be careful if you swap mirrors....be absolutely sure new ones are specific for the newest Ram series. My son swapped his mirrors for some off of an older model. The fit fine, but the newer Rams have the the outside temperature sender in the driver's mirror and the older ones had it under the hood by the front grill.
He didn't realize that the sensor was missing and the truck went crazy....started shifting erratically, would not always start, check engine light came on, etc. He took it to the dealer and it cost him a $95 diagnostic fee when they told him to switch the mirrors back....then, all was well....ugh
If you want to troll with your mirrors, run with one up and one down lol
