Need Help. Adjusting Headlights
Mad Cow
Anchorage, AK
Cummins 6.7
So I finally got my truck back from the body shop and I had it lifted more while it was there and now I am really blinding people. How do I adjust the head and fog lights in a 2011 Ram? Thanks for the help guys.
LB3711
Trumbull, CT
3.6L V6
For the headlights thru the hole where my key is pointing uses a torx bit.
Sent from my AT&T iPhone 4.
Vendor
Florissant, MO
2x 5.7L & 6.2L
Fogs - there is a dial on the fog. Spin away!
quietpeen
2021 TRX
Hellcat
good to know
MiRamDriver
I probably should do this now as well. My 55W HID's and lift are probably not pleasing others on the road...
Mad Cow
Mad Cow
Anchorage, AK
Cummins 6.7
I can't find the adjustment for the fog lights.
quietpeen
2021 TRX
Hellcat
when JJ see's this I'm sure he will be able to explain where it is. I have not had a need to crawl under the truck yet to have a clue.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
kinda hard to see.......
12:00 position, from the back, there is a dial that you spin. When you are under the truck, its in teh 6:00 position. I think.
Mad Cow
Mad Cow
Anchorage, AK
Cummins 6.7
is it that white plastic circle with a bolt in it?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Yup!
So......I took some better pics. I happen to have a few of these sitting downstairs, they have a date with the oven soon. ;)
These are flipped for better pics
this is how it sits in the truck - there is a bracket that they snap into
and a close up on the adjuster
