Need some advise
mike.t
Socal
2015 2500 6.7 C/C 4x4
2015 Ram 2500. Message say's R/R 69 psi fill to 80. Checked it and it is about 80.
Can only open Tail gate with valet key.
Thanks
Mike
Jerry1984
Meridian, Idaho
It's under warranty. Take it in when you can. Bad tpms sensor possibly.
MADDOG
Not RamForum Staff
I agree. Sounds like a bad sensor and the lock thing may either be a connection or a flash to the computer to activate the solenoid properly.
Duaner
Shift Lever Access Cover
Hello Guys. I am new to the forum so bear with me. I have a 2012 Ram 1500. The Console Override Shift Lever access cover came up missing. Where can I get one? Have checked MOPAR parts and have had no luck.
darthdzl
Phoenix, AZ
2017 Tradesman RCSB
V6
First if all, welcome to the forums. :welcome:
Secondly, you might have a better response if you post your own thread. Tacking your question on to a thread that has nothing to do with your problem might delay getting help.
Thirdly, you might want to post in the right section. I'm on my phone, so it's harder to see what section this is, but it's almost certainly not the Interior section of the 4th Gen forum, which is where it sounds like this belongs.
Once you repost your own thread over there, it should be pretty quickly that someone's able to locate a source and/or part number for you. In fact, I'll look for your thread and do some searching when I get into the office.
Good luck, and welcome to the Ramily! :D
EDIT: Okay, it looks like you posted in 4th Gen General. Not a horrible place. Probably the second-best place to post this one. I still think Interior would be a better place to post your question in your own thread, but General wouldn't be a bad runner-up. Don't post in both, though...cross-posting is kinda frowned upon. :) Good luck!
