I was in the same situation as the OP. I went ahead and got the Bilstein 5100s and have them set at 1.4"
But, just like when I had my jk, now I'm looking for more altitude. So I'm at a crossroads and my research might help mrsundays.
Option A
I can move up to 2.1" on the bilsteins and be about 1/8" from perfectly level. BUT, I actually like the 3/4" rake I have because I always carry $h!t in the bed of the truck and tow every so often. I am thinking of adding SuperCoil HD springs (#SSC50) for $350 which will give me 3/4" lift in the rear and help the rear from squatting so much when I tow.
Option B
I can go with the bils at 2.8" in the front and add Icon 1.5" lift springs in the rear for $295 but then I'll probably need bilstein shocks in the rear (they are about 1" longer than stock). So it will be about the same price when all is said and done.
Not sure which way I want to go right now... I've heard mixed things about the Icon springs giving more like 1" of lift which means I will be level when fully empty and nose high with my crap in the bed of the truck or towing....
kinda leaning towards option A. Downside is less lift, but upside is less chance on being nose high.
mrsundays, honestly, I think it'll be just like with the JK, you'll be happy for a while, then want more lift and larger tires. I should have learned my lesson with the JK
If I was starting over again, I would have just gone 4" superlift and be done. Since I no longer have a garage or time (2 boys in sports and assist coaching my oldest's team), having to shell out for the body lift, bilsteins fr&rr + labor puts the 4" superlift close enough to justify going that route IMO.
Good luck & post picks whatever you decide.
take a look at post #9 on this thread here:
http://www.ramforum.com/f40/zone_v_superlift_300_difference-75491/
