Hookie
How much should a oil change cost at the Dealership for a 2015 Ram 5.7 with full synthetic oil?
I don't know but it is way cheaper if ou do a contract. I never do full synthetic in my truck
cost extra 194k miles laterstill no full synthetic
like what? I do oil changes every 6k to 7500 milesIt does cost alittle more but you can go alot longer between oci using synthetic oil.
Thanks for the info guys. The only reason the dealer changes it is due to a disability.
I think i'll ask about a contract next time i go in.
Never had a full synthetic change done by anyone other than me. The difference in the cost of oil is minimal at Walmart. I have a feeling dealers, oil change places and everywhere else treat it as a premium service and charge accordingly.
I change my truck at home and it only takes 15-minutes. It is actually easier than taking it to the dealer except in foul weather. Wait for good weather.
Either way... 5 Quarts of synthetic at Walmart is $17-$25 for your standard fare synthetic. You may want to stick with the Penzoil flavor that is MS-6395 if under warranty. "Standard" discounted motor oil that is still MS-6395 rated is around $12-$18 so about $5 difference per oil change.
I think if you stick with anything that is MS-6395 rated you cannot go wrong. I'd ignore the synthetic vs. dino oil thing. As long as you stick with oil that meets MS-6395 and is of the appropriate viscosity your engine won't know the difference. (flame suit on).
