Part Time t case slow to disengage and bangs
gassyplumber
2010 trx4 hemi crew cab
Hi guys. I have a '10 1500 trx4 hemi crew.
Occasionally the t case will not disengage for a few minutes then lets go with a bang/ thud like I hit something.
Any ideas?
Hemi395
Cape Cod MA
Almost sounds like the shift mechanism is hanging up. How old is the fluid?
G
gassyplumber
Its original as far as I know. 55,000 kms
Hemi395
Cape Cod MA
A fluid change wouldn't hurt. Might fix it, might not but I would start there...
TerraNewf
NL, Canada
Ditto on the fluid change, cheapest fix if it works.
dunney
Did you end up changing the fluid and did it help? I think I have a problem with my transfer case and I'm trying to do some research.
Also, is it a Borg Warner?
G
gassyplumber
I will get a fluid change booked. Not sure which t case I have. Build sheet just says electric shift on fly part time. It's not the 4auto
Thanks fellers
dunney
Thanks fellers
Please ask whomever changes the fluid what t case you have. Mine says Borg Warner right on the case. Maybe take a picture? I'm trying to find someone who has the same set up as me so I can narrow down what is wrong with mine.
G
gassyplumber
I will most likely take it to dealer next week.
G
gassyplumber
I have a :
New process gear 243d tcase
PippinAin'tEasy
Not saying this a fix but some guys with ageing electric 4x4's advise going in reverse for a couple of tire rotations after coming out of 4hi/lo. Something about helping re-seat the shifter away from the gearing? At any rate I hope you guys get the answers yer after.
"Oh, sweet debt. Thy name is Truck."
