Princess v2 headed to the dealer.......
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
They are replacing the ring gear.
I called them around 1 today - he said it was a 50/50 on getting it done today...........well, its not done. :(
He set the phone down, I heard him ask some dude what was wrong, I hear some other dude say "are the parts in? Check that box over there". He picked it up.......said "Damnit, this is ******' heavy - what is in here?!?!". "Gears - the other ones are ******!"
Errrrrrrrrrr.............yeah, from riding around with so much AIR in the bed.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
very nice jeremy, you managed to cause the beginning of the 4th gen screwed up rearends club, 3g rams it was clips, will the 4th gens be ring gears?
hope they get you up and running quick!
myoung84
Tulsa, OK
2012 Power Wagon
Did you ever check the diff fluid? I know there were a bunch of truck that left the factory with low or no fluid. Just a thought...
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
^^^This and its all dealer maint. so its their fault. Silly Stealership.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I didn't do ****. Warranty - there is absolutely no reason to have low fluid at 6,600 miles.
They better call son, I want my truck back! They are putting new gears and bearings - basically rebuiding the entire rear end.
xoom xoom tapatalkin'
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Parts list of what was replaced today........and some prices I could find on the net.
5010322AI 521.92
68056356AA 13.20
5072498AA 20.50
3507678 7.35
5017438AA 50.20
5072506AA 36.10
2x 52111197AB 14.22
2x 52111198AB 9.50
3x 4874469 30
Total Parts - 786.71
New ring and pinion set, seals, bearings, lub, etc.
Also had 2 RRTs done while it was there.
10-020 - The Cluster may appear blank on start up for a drive cycle. It may restore operation on the next key cycle. Other noticeable concerns would be unable to change language via Hands Free Module on either High Line or Low Line clusters. Dealers are required to flash the CCN.
good thing........mine did that the other day!
10-022 - Reflash wireless control module. I asked them if this would interfere with my aftermarket remote start. "No". I haven't tested it yet.
Declined 09-096 - thats the one that they smear silicone over your 3rd break light.........mine isn't leaking and I don't want silicone all over the place.
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
That 10-020... Wouldn't have anything to do with the EVIC just flatly refusing to update itself, is it? Mine didn't want to update the instant fuel and temperatures yesterday. No way in hell could it read 34* outside when it was almost to 80*.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
not sure on that one........
