HEMIHEMIHEMI
Hi from Florida! Firstly let me apologize for not starting out with an introductory thread but I ran into some issues buying a RAM 1500 and am now looking for some advice so hoping you, the experts on this topic would be willing to help me out.
Long story short, I purchased a 2013 Laramie Longhorn with 37000 miles on it. The car was originally from Philadelphia so I assumed it would have seen some snow. All looked well; interior as I wanted it, in black with white gold and with a 3.92 gear ratio.
So because this car came through a superstore (which I don't think I should name, yet you likely understand who they are), I have a five day return option so I brought it to my own mechanic to check out. Long story short he wants me to return it due to excessive rust. Also, the right front shock absorbed is leaking, the right front axle is leaking (the boot I assume?) and there's impact marks on the control arms and that is the one that worries me most. Then my mechanic says there's just too much corrosion on the brake lines, the power steering lines and the coolant hoses need to be replaced. He's worried that because of the rust maintenance is going to be disproportionally expensive as he'll likely keep on shearing off heads and such. Then again I don't know what's excessive as mechanics down here tend to be allergic to rust.
My question is whether any of you would be willing to give me their opinion based on the attachments on whether they think there is a price point at which I could keep this truck or that I should just take the slight hit and return it today. I didn't pay top dollar for this car either; likely this is why but I'm not sure if that should justify this condition. I'm pretty sure they'll offer to deal with the shock absorber and axle but I doubt they'll replace anything preventative such as brake lines, power steering lines and coolant hoses, let alone control arms) Also the undercoat doesn't seem to be very good and sprayed over the rust but falling off I suppose that would have to be redone as well unless it's too late...?
I've attached some pictures below... I'd really appreciate anybody's opinion on whether I should walk away from this car now or not... Many thanks!
P.p.s. I've been looking around for an alternative with the 3.92 gear ratio... I can find only one in a 500 mile radius although I don't like the interior nor the color too much...
