Dodgefan1983
- Nov 26, 2012
- 4
- 0
- 2013
- Cummins
Hello!
i am interested in getting a heavy chassis cab truck, most likely either a Dodge 5500 or a Ford F-550.
No it comes down to compare some parts and how they can be compared when it comes to use them offroad and/or with heavy payload.
So first things first i like to get come informations about the frame since it's the base component of any truck.
As far as i know, Dodge uses 50.000PSI steel while Ford's only using 36.000, so definetly a plus for dodge, but how are the measurements? I got a material thickness of 7.7mm from an 2011 pdf document but thats it. (fords using 8.1mm and adds up a 7mm sleeve in the middle section, probably necessary because of the weaker steele)
So anyone got the height and width of the rails in the middle section between the axles? (i know the dodge frame changes its height, while the ford is all way streight 7.5 inches, so this might be a little tricky)
And how about the boxed front part? Is it also 50.000psi? And is it always the same on all chassis cabs from 3500-5500 or are the 5500 boxed front parts thicker or bigger somehow? (In the case of ford those parts do differ, not in the outer dimensions, but when it comes to meterial thickness)
Thanks for any further information!
Greetings
Greetings
