I remote started my new/used 2011 Dodge Ram tonight because it's snowing like hell and I wanted to defrost the windows. I came out five minutes later and the truck was already turned off it did warm the windshield a little bit but not completely. Can it be programmed to run longer on remote start.?
Sent from my Samsung Note 4
Hi jljbtm,
Page 27 of your Owner's Manual, which you can download from the Knowledge Center on
www.mopar.com, states:
"• The engine can be started two consecutive times (two 15-minute cycles) with the RKE transmitter. However, the ignition switch must be cycled to the ON/RUN position before you can repeat the start sequence for a third cycle."
If your vehicle is equipped with the factory remote start system and isn't operating as described above I would recommend visiting your local dealership for further diagnosis. Please let me know if you have any additional questions!
Andrea
Ram Social Care Specialist
