Rolling stone is driving me crazy
Apiazza
Westminster, MD
A month or so a go I noticed the sound of something rolling around under my truck. It was pretty obvious that on braking it rolled forward, on acceleration it went back. Always on drivers side. I got under the truck to try and source the issue, initially thinking it was a rock in the frame. After some digging around I believe I actually found it inside the body under the doors. 1 in a billion chance of kicking a rock into the tiny holes on the inner side of body. I would have much rather won the lottery...
Anyone have some recommendation for getting it out? I could probably use a borescope isolate it's location, but don't know how I would be able to get it out after I found it. I've considered pushing it all the way to the front or back and then using a bit of expanding foam to try and seal it in place. My only concern going that route is water drainage out of the panel. I don't want to trap moisture and create a rust issue. Thoughts?
lukedukem
Victoria, Tx
can you post some pics of where it is exactly? and maybe what holes are in the area
Luke
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
if you can find it with a boroscope, then put some chewing gum or tape on the end of the boroscope and get it that way (but don't block the seeing part of it)
Apiazza
Apiazza
Westminster, MD
I'll get some photos for you tonight.
The tape/gum on a stick might work, but will definitely take some finesse to get in those angles.
U&A
Michigan
2016 3500 SRW
6.4 HEMI
:lol:
TRCM
USN, Retired
Newport News, VA
Just the opposite here...since I quit smoking, the windows are always up & the A/C on.
Radio, maybe maybe not.
Apiazza
Apiazza
Westminster, MD
So this is looking at the body as is runs below the doors. That tape appears to have pulled off some and I'm guessing that's where it entered. It just rolls back and fourth. The odds seem so low I wonder if someone is screwing with me.
U&A
Michigan
2016 3500 SRW
6.4 HEMI
The tape was peeling off of all the holes on mine I pulled it all off. They need those access holes for the rust prevention spray when I do the underbody anyways.
BlueRT
Ohio
Maybe a flexible hose connected to your shop vac?
TRXHemi
Sugar Land, TX
Check inside the floor storage bins behind your seat....I once had the same issue, and someone had put something in the floor storage that was bumping back and forth. Drove me nuts until I found it! Maybe??
Apiazza
Apiazza
Westminster, MD
Vacuum could work if I can get it in there. I'm going to spend some time this weekend screwing around after I replace the windshield washing fluid pump in my fiancé's Santa Fe
U&A
Michigan
2016 3500 SRW
6.4 HEMI
I looked under there at mine again. So there should be 3 big drain holes on the pinch weld. Unless the rock is to big i would just run a garden hose and flush it right out.
Apiazza
Apiazza
Westminster, MD
I'm going to assume it's too big because with all the movement it does I would guess it would have fallen out by now. I'll probably try some air in there as well.
U&A
Michigan
2016 3500 SRW
6.4 HEMI
If the water can wash it over the hole so you can see it, reach up there with a pair of plyers and crush the FU$&er. Or rip it out.
avantiguy
Bay City, Mi
hemi
Bend an "L" shaped piece of metal wide enough to fit in the hole. Wrap Gorilla tape around the 1/2 that fits in the hole, sticky side out. Tape the other half of the "L" to the door bottom. As the rock rolls around, it will hit the tape part and stick.
You can then deal with it.
ColdCase
Anyone get one of these "rolling stones" behind the driver or in the bed area and figured out where it was ? I don't think its in the area under the door and it may be a nut that loosened and fell off. I can get it to roll on sudden acceleration or stopping but also hear it sometimes on sharp left and right turns.
I've owned pickups now for 40 years and at times something will roll around in the bed, but this bed has been swept clean. I thought perhaps one of the bolts holding the AMP power steps came loose, but this noise appears to be behind us. I have a regular cab, no under seat storage.
