Strange thing happening.. What is it?
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
The past couple days I've noticed that when I come to a stop at a light or anywhere I get a thump from the rear and I feel the truck act like it wants to move forward. As if the gears are trying to keep me going forward. The is about 1 second delay. So I so completely...1 second later light thump and it jerks forward. Thoughts?
Sent from my XT1635-01 using Tapatalk
Broyd
Rossland BC Canada
Your fuel sloshing forward in the tank and coming to an abrupt stop? That would give you a bit of a delay. My 2011 Laramie did this but I haven't yet noticed on my 2016.
huntergreen
32 gallon gas tank thump. no baffles in the tank.
jasonw
South Dakota
5.7L Hemi V8
I've always heard three different theories.
1. Fuel slosh, as described by others above.
2. Transmission shifting.
3. Two piece driveshaft slipping slightly together and then back apart (or vice versa).
Regardless of which one is correct, it is normal and nothing to worry about.
VB712
Maxi_built
Va Beach
Mine does it too. Thump at an almost complete stop, then a slight delay when I go to accelerate again. I have a 1 piece driveshaft so I assume it's the fuel.
02blkram47
02blkram47
Lebanon, NH
Thanks for all the reply this is great news. Of course my mind went straight to expensive.
Pmexpert
6.4 SRT
Is it is fuel, just fill the tank full if thump still appears, try to run with a scanner connected to make some logs to see how shifting is done.
02blkram47
02blkram47
Lebanon, NH
Good idea
et todd
my 2014 and 2015 did it my 2016 doesn't.annoying as hell.common denominator with the first two 3.92 gears ,two piece driveshafts and maybe us built transmissions.i greased the drive shaft on the 15 and it still did it so i rule that out.and against popular belief in 15 and 2016 anyway not all hemi 8 speeds are built in germany.on my window sticker the 15 said trans origin usa and the 2016 has germany the 16 is a 4x4 though so maybe 4x4 transmissions are built there.
