Tpms id?
pajeepman
SE PA
5.9 magnum
Just pickup up some 2016 1500 take off rims, forgot to ask if the have tpms. Is there anyway to tell just by looking at valve stems? I do not need them on my '03, just wondering though. Stems look like "normal" ones to me. Thanks
Sent from my SM-J320P using Tapatalk
MADDOG
Not RamForum Staff
There's no tires on these rims, right? Is there a ********* plastic box attached to the backside of the valve stem? If so, that's TPMS. You can pull them and put in regular valve stems.
pajeepman
pajeepman
SE PA
5.9 magnum
No, tires are mounted. Could a larger amount of weights directly opposite of the valve stem be a sign?
stimpy433
IOWA
You could take them by a local tire place that has a TPMS reader and have them see if they get a reading from them....
pajeepman
pajeepman
SE PA
5.9 magnum
Did not know that was an option. I pass 4 or 5 tire places on my way home from work everyday.
radikio
