Took my truck on Monday to the dealership to have a recall completed, tie-rods replaced. When I got the truck back and drove it home the steering wheel was turned to the left! They told me they do not do alignments on vehicles unless payment is made. (separate from warranty/recall) My truck did pull slightly to the left prior to the service, but they not only didn't know this, the steering wheel was on center. I then took my truck to a mechanic who adjusted the wheel back to center and completed a full alignment. Now the truck still seems to be pulling to the left again, however, not as bad. Do aftermarket rims and larger tires cause this to occur due to groves in the roadway, it does seem to be worse on the highway. Does anyone else seem to have a similar problem?
Your truck might fall within this TSB (Technicle Service Bulliten - Tsb sb-19-004-10: Steering wander )
Check this link out: (#4 Perma Link)
http://www.ramforum.com/f53/4th-gen-technical-service-bulletins-2284/
First check the tire pressure on all 4 tires.
(on my 2010 1500 4x4 QC, i run my tire pressure @ 38psi)
Then rotate the front tires to back, back to the front. (wheel nut torque 135ft lbs)
If you notice a good amount of difference after the rotation, my guess would be junk tires.
Now as for your dealer that did your tie-rod recall... find another dealership..!
The recall says AND states, to re-set the toe AFTER replacing the tie-rods.
If your steering wheel is not straight, the monkey that did it, didnt know what he was doing..!
A good alignment tech ALWAYS sets the s/wheel straight and locks it down, then brings the tie-rod adjustment in to spec.
