Trying to find drivetrain info
Iggy4935
I've been on google for about an hour trying to find out what the drivetrain is in these trucks. This is my first Ram a 17 1500 4x4 with the 5.7 so I'm not very familiar with what is used. Just trying to find out what front/ rear axles are and the transfer case. Thanks.
I
Iggy4935
Go here and look under equipment info. Type in your vin# and it will tell you everything
Dodge - Contact Us
Thanks. Trying to find more info on the transfer case. Like what the low range ratio is.
clh1220
st Louis
The build sheet is not going to tell you those specs.
huntergreen
don't know where you would find that info.
I
Iggy4935
I tried looking up the bw44-44 but there isn't much info on it.
monteholic
Michigan
6.4 hemi
does your truck have the auto 4x4?
if so you should have the BW44-44
if not you should have the BW44-45
they both have a low range 2.64:1 ratio
I
Iggy4935
No auto 4x4 just the push button 4x4 high and low. Thank me for the info
lasse452
