I have not been feeling good recently and the sub zero temperatures make it difficult and time consuming to heat my garage. So i decided that I would temporarily tap into my fuse box with a add a circuit and connect it to the hot wire for my led light bar DRL's that was connected to my battery.
I did not have Micro 2 fuses leaving me with only the two 10amp fuses that came with the add a circuit. So i decided it would best to use a 10amp fused spot in the box. the easiest and fastest one to use was the one for my TIRE INFLATION INDICATOR SYSTEM.
5 MIN down the road my dash lit up like a Christmas tree and claimed i had no right rear tire and needed to check my TIRE INFLATION INDICATOR SYSTEM.
I first checked the tire to be safe and wise. Then i turned off the led light bar DRL's and continued down the road. 5 min later my dash went back to normal.
So on my thru town i stopped and picked up some 20amp fuses and plan to change the location of that add a circuit tap to the radio or something that will be using a 20amp fuse.
I have a "
Led Daytime Running Light Automatic ON/OFF Control Module Switch Relay DRL" that i will be installing soon enough.
