It could have something to do with the sensor inside the tire on the wheel itself sometimes if they get moved at all (by a tire technician) so if it does not go away in a couple of days take it to the last tire shop that you were at that mounted the tires and see whats going on, just wondering myself when was the last time you had tires worked on???
Holy hell. It took me a second to realize this was a Canadian truck. I saw 330 and I was like wtf?! Don't the 1500 tires recommend 42 psi or thereabouts? 330 kPa works out to almost 48 psi so maybe the pressure is too high?
P.S. for the cold weather thats normal what happens is that the tire pressure drops in cold weather and rises when tire tires heat up from the road in the summer both affect the pressure by about 10psi.
Yeah that must be it. It only happens in cold weather and it goes away after a bit of driving.
**EDIT**
I seem to remember a conversation with my dealer about it shortly after I bought the truck.
I think it may be possible for them to reprogram the TPMS system to be slightly less sensitive. I could be remembering that conversation wrong, but it may be worth asking your dealer about it.
Sorry... must be getting old. My memory past yesterday is sketchy at best.
