2/4" drop with BellTech kit
Blue's Ram
I just installed the BellTech 2/4 drop coil springs and street performance shocks on my Ram. it took about three hours with a lift, for the most part it was a pretty simple installation. The instructions were easy to read as well. I did take it in for a front end alignment and the tech said it was off , he had to do a good bit of adjustment to bring the tires back in, but all in all, it rides much nicer than the factory springs and shocks and I like how it sits especially in the back, it really took out that gap between the top of the wheel well and tire.
Avgas
Florida
2015 Express
3.6 Pentastar
Very nice, did you cut the bumpstop cups up front?
thumperpa
Freedom, PA
2013 QCSB 2WD
Nice
Looks awesome can't wait to get mine done
B
Blue's Ram
Thanks guys. I left the bump stops cups up front but did install the BellTech bump stops, they fit nicely with no cutting needed. Iv put about 3K miles on it since the drop with no issues.
thumperpa
Freedom, PA
2013 QCSB 2WD
Crossmember
Did you have to cut out a piece of your crossmember
Quicksilver337
South FL
2016 Ram R/T
Belltech install instructions say to remove the front bump stop cups :shrug:
chizzyofdp
houston, TX
4.7 v8
The srt wheels would look killer on your truck! If you're into that sort of thing :naughty:
1Popeye
