2 inch drop with mud tires.
CRam
So I'm looking to level my truck but plan on running stock height tires and don't want to put stress on cv shafts, ball joints... so I thought I could level the rear but it is 4x4 and I like going off road. Would this look weird with mud terrains? Anyone do this or have similar pics?
Etroze86
Grand Forks ND
I have a 2/3 drop on my 4x4 and I love the look of my toyo AT2s
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Well your already off to a bad start - sorry. You wanna go off road, but you wanna level it (drop the rear 2")... the ball joints and CV's will be least of your worries, you need t level at the other end of the truck.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Here is my 4wd with a 2" rear drop and 305/55/20 Nitto Terra Grapplers...
And the current setup is a 2/3 drop with 305/50/20 Cooper LTZ's...
SilverStreak88
Houston, Texas
5.7 Eco Gasser
How did those Nitto's wear on you? I've 2 set's and never got more than 40K out of them. I did however get almost 55K out of my Trail Grappler's.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Those tires were only on the truck for about 2 months before I decided to go lower. I don't think I have ever owned a set of tires long enough to wear them out. I have run terra grapplers on 4 trucks though, and never noticed any faster wear or any problems with the tires at all. I would definitely run them again if I had a need for a larger tire.
C
CRam
Sorry I fell of the grid. Thanks for the replies. Thanks for the pictures too but now I see I don't want it that low.
1Popeye
