locobrutus
To those who have the adjustable ball joints which ones do you have. All comments good and bad would be appreciated. Sense there is such a wide range of prices. Thanks
Thanks for the reply.I was planning on buy the SPC ball joints. Found them online for $86 . I have a 2/4 drop and have already maxed out all of the adjustment for camber and caster. Looking to do this very soon.
I had the Moog ball joints.
They worked to correct my camber problems when the truck was sitting still, BUT they push the upper control arm even further up, meaning the camber gain when the suspension is compressed is even higher. I ended up removing them because they were so problematic.
wow good to know about the moog...what are your thoughts of the spc ball joint.
The spc only has a max of 2 deg positive camber, the moog has 3 deg positive camber.
I ordered the SPC adjustable ball joint as well, I think I'll be going that route. Once I get the spc I'll compare it to the moog
Any word? I am getting ready to order all my suspension and am trying to decide between the SPC or the Moog.
Thanks
