blackhemi16
- May 11, 2016
- 73
- 54
- Southern California
- 2016
- 5.7 hemi
I just got my beltech 2/4 drop spring only kit yesterday and i was going to do the rears today and finish tomarrow but i got stuck. I was working on the rear first and got the spring out and put in the belltech spring. i noticed though that the spring is like 2 inches or so shorter than stock and i had a feeling that it was going to rattle when install it. Sure enough i just did the one side put everything back together and started bouncing the bed up and down to see if it will rattle/shake and it did. SO i was wondering has anyone else do the spring only kit with factory shocks and if so how did you fix this? I know i should buy shocks but i really dont want to spend anymore money right now and ive seen/read a lot of people who did springs only and are running fine. Can you please give me tips on how i should go about this. Thanks. Another odd thing i found out was the stock bump stop isnt even bolted on, i was able to pull it right out, is it suppose to be like this? it wont fall out? This is on the rear. well thanks.
