Belltech Actual Drop Amounts & do helper bags effect ride height?
N1ck
Regina Sk
Apologies in advance for the long title, didn't want to make two threads.
Question 1
I've read some conflicting information. Who here is lowered and added durango airlift bags? Has anyone taken before/after measurements? Did the addition of the bags increase rear height?
Question 2
Who here is running BT 2/4 drop? Did you see 4" of rear drop or is it closer to 3"?
razor1
St.Petersburg Fl
airlift bags in the rear, you can get also 1" lift with them. Never really measured the drop because I was happy with the way it looks.
N1ck
N1ck
Regina Sk
Are implying you can achieve 1" lift with the bags at a high(er) psi.
The reason I ask is I've got 1" drop springs in the front and only want a max of 3.25 in the rear otherwise the back will be lower.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Belltech 4" rear coils will get you a full 4" rear drop. You can lift it back up using the bags though. My truck lifts 1.5" with the bed empty and the bags inflated to 35psi.
adurm
FL
2015 RCSB
I have a bt 2/4 rcsb and I have just under 2 inches from tire tread to fender all around. No bags.
N1ck
N1ck
Regina Sk
The 4" rear drop kit 5318 should pair up well with my crown front springs and durango bags then. Uh I should have really bought a complete kit instead of trying to save a few bucks!
6speed4.7
Winnipeg
I hear you...
A couple of US dollars or 19 dollars Canadian
Sure was easier put it together when it was closer to par
Uaintlo
quick question.. the airlift helper bag kit for the Ram will fit with a lowered rear coil?
thanks
Uaintlo
yep, i'm on a 2/4 drop, they are worth the little extra $'s
thanks for the info,
do you have the standard bags for the Ram #60818,
or the Durango bags #60824 (suggested for lowered rams)?
Gary's Hemi
Walker, La
How does the Crown Suspension springs up front ride?
moregrip
do you have any pics of your truck you can post? It just looks badass from what I can see of the one in your sig:favorites13:
