Alaskanpeeps
- Mar 7, 2016
- 99
- 23
- 2013
- Hemi 5.7
Im 4wd but here is my experience anyways. I'm down 2.5" in the rear, everything else is stock. I've never hit my stock bump stops unloaded. Mabe twice with a couple hundred pounds in the bed. As far as my rear sway bar goes. Its about 1.5" from being level so I need to get some hellwig 7961 8"-11" adjustable end links. I think those bell tech links u got will be way to short. As far as the track bar bracket goes. U can drill a new hole to raise the track bar about a inch on the frame side to level it out. The bracket will just put you off level the other way. I believe it's not needed till 3 to 4" of drop
