Cut coils
xxxotiknightz
Salt Lake City UT,
Has anyone cut their coils on a new ram. I've seen it done on other sites and was wondering if anyone had tried it?
adamwilkes14
I dont know anybody who has done it in a Ram, but know alot of guys who have done it on S10's and it really made their ride go to ****...they would even heat the coils up and compress them...same result.
DeputyDipShizz
Pennsylvania
After many years of seeing this done...a seeing the results...I can't believe people even consider it as an option
-TapATalkAholic-
scoose
Atlanta
2007 1500 sold, 2011 1500 5.7 sport sold, 2016 6.7 2500 4x4 sold, 2014 2500 5.7
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Theres a fella with a white R/T on here with them cut. If I can think of the name I will ask him how his is doing.
Copperhead
Chesapeake, VA
I cut a coil out of the rears on my drop kit to give me a 5" rear drop. I have drop coils and spindles up front for 4" drop.
xxxotiknightz
xxxotiknightz
Salt Lake City UT,
I like the look of your drop. I've seen big name customizers cut a coil to get the height right. but then you hear all these horror stories. I may do like you did and just do a rear cut.
mitchman
SC
For the little bit of money you spend I promise you will be happier with a full drop and lay that truck out over those tires a little better
xxxotiknightz
xxxotiknightz
Salt Lake City UT,
Im thinking I may do the same drop as CH. I like the stance. Then add some SRT 22's to finish it off.
Copperhead
Chesapeake, VA
I cut a coil out of the 4" McG drop coils to give me 5 inches of drop. I have an extra set in case I didn't like it or screwed it up.
As for the SRTs.... like this (when I was only at a 2/4 drop with Nightrunner SRT 22s):
xxxotiknightz
xxxotiknightz
Salt Lake City UT,
Im thinking I'm going with the Chrome. I like the 2/4 but that little bit makes the look. CH how's the ride with it that low?
Copperhead
Chesapeake, VA
Now, or when I did it? When I did it fine. Now that I need new shocks.... not so good. LOL
I am still running factory shocks with this drop 2 years later and I really need to find a lowered set.
cmerritt84
Central GA
yea id rather just get the lowering springs. i mean god lord this is a 30k+ truck. why hack it up
jcolvin
I've cut springs on several trucks and have never had any issues. I just bought a 2012 Express and cut 2.5 coils in the rear and got about 4.5" of drop. It rides almost as good as stock. The only issue I have noticed is when using stock rear shocks, at full extension your cut springs can just fall out. I replaced mine with belltech drop shocks and problem solved.
