Milt IV
- Aug 18, 2015
- 321
- 110
- TX M'F'er
- 2015 Sport
- 5.7 Hemi
Need to cut a little off the rear springs from my ground force kit to get the back down to level it out. Do I cut off the top or bottom of the spring? I'm sure after getting down there and looking it will become obvious but I thought why not get a head start in the planning department.
I had read that 1 full coil yields about 1" of drop but I think that was on the BT springs. Anybody done this on the GF springs? If so, how much did you cut and how much drop did it yield you? I know the GF and BT springs look totally different side by side so I wouldn't be surprised if the same amount cut gets you different results between the two.
