Factory 2wd spindles on 4wd for drop?
N1ck
Regina Sk
Curious if anyone has pulled this off and achieved about a 1" drop? Installed factory 2wd spindles on a 4wd.
Lighter coloured spindle is a stock 4x4 spindle, dark is 2wd. Looks like the tie rod end is lower on the 2wd and the ball joint (upper) is slightly different.
I'm looking to add about 3/4 - 1" to balance out my truck without breaking the bank.
BrBlack
Calgary Alberta
This mod has been in the back of my mind for years.
I've heard the 2wd spindles should work on a 4wd to lower the front as you've said.
Haven't done it myself but would be interested to get others feedback that have.
charonblk07
Calgary, Ab
F1-A forged 349ci
The 2wd spindle works just fine on the 4wd and gives you ~1" drop over the 4wd spindle. We use them with the GF drop springs to get a 3" drop and not have issues with the inner CV joints.
N1ck
N1ck
Regina Sk
Thanks for the replies guys.
jw97neon
do you by chance have any pictures maybe before and after. i just picked up a set of knuckles. i have yet to install them.
BigHornGuy
Florida
5.7l
Hello there sir, this is a long shot since it's been over 5 years but, Could the same be said backwards? 4wd spindles on 2wd for ~1" lift?
