Hellwig rear swaybar?
RagingCrayon
Your Mom
Ill be looking for one when my '17 RT comes in. I will probably be doing a 2/4 drop. Which swaybar is everyone running?
Hemicuda61
Jeeperf's
Sent from my HUAWEI MT7-TL10 using Tapatalk
bgray
Canada
I run hellwig front and rear. Rear helwig adjustable links and front F150 links
Trapinator
Houston
How you like the f-150 links? Was thinking about getting those. I only get the wobble past 110
bgray
Canada
They do the job. My trucks never been past 80mph id say so i dunno
Slowpar R/T
5.7L
I'm running the rear Hellwig Part number 7709 on my 2014, which according to Hellwig's website works with 2017 as well.
12vrunner
Texas dfw
I got the rear hellwig and i get wobble under hard acceleration at about 60 to 100. Which hole did you guys use i did the middle one. Also if i were to move holes would that affect alignment. And as stated before i think the stock tires are junk which cause a small role in this.
Slowpar R/T
5.7L
I'm pretty sure I used the middle hole too but I don't have any wobble to about 90 (but I haven't been over 90 to test when it may come back)
