KCaudill
The RAM
- Mar 10, 2016
- 434
- 135
- Blacksburg, Va
- 2016
- Hemi 5.7
As the title says. Is there a manufacture that makes a lowering kit for the 2016 1500 4x4?
Can you help me with figuring out what I need to do with the 2/4 kit from MCGaughys? I have a 16' ram 1500 4x4 and I would like to use this kit but I have been told it is "not recommended" Mine is a quad cab also. Thank you in advance!
Josh
You need to check the clearance of the lower control arm at the balljoint with the spindle if it doesn't have the machined window in it besides that it's a straight install. As Matt stated it does push the front track width out 1/2"-3/4" and I was running a set of rear spacers to even it all out.
