Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lowered
Lowered
Lowered Suspension: An Engineering Perspective.
This is a discussion on Lowered Suspension: An Engineering Perspective. within the Lowered forums, part of the 4th Gen : 2009 - Present category!
Originally Posted by moregrip Something maybe worth looking into for those that have the adjustable Spohn arms. I actually like ...
Like Tree11Likes
Reply
Old 12-19-2016, 04:59 PM   #11 (permalink)
Dubstep Shep's Avatar
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
I actually like the Spohn arms quite a bit except for the frequent adjustments and clunking, as many have stated.
My thought was to get an ID measurement of the stock control arm bushing ring, then find a way to machine out the threads/extra material on the one side of the Spohn control arms to either the same ID as the stock control arm where a stock rubber bushing(think Moog replacement) would be pressed in "or" if that ID was to large once the required material was removed, machine a weld-able bushing ring with the requisite OD and the same stock ID/width as a stock control arm ring.
In this case, you would have a serviceable bushing, low NVH, and an adjustable arm.
They're not really anything special.
Adjustable control arms are a pretty straightforward deal.
You can buy threaded, weld on inserts to put on DOM tubing and then just have one right-hand thread and one left-hand thread end to put on. They even make forged ends with poly or rubber to thread into the arms themselves. That's what I'm looking into currently, and depending on how it's done, you may be able to use the same arm with different ends, meaning you could run poly on the same arm as rubber or even solid. That's a big cost reduction in the end.
This place sells the threaded tube inserts: http://www.barnes4wd.com/Tube-Inserts_c_16.html
Here's what I'm talking about with the different ends. This place sells both solid and rubber threaded rod ends, so you could use either.
Pics:
Rubber rod end:
Solid rod end:
Link:
http://www.rustysoffroad.com/builder...d-ends-inserts
I just need to either find someone to weld the ends on the tube or finally pony up and buy a welder.
need some pics of that cut front coil on and off the truck brother!
Sadly, I never took any pictures after I cut the coil. The girlfriend was complaining about me being busy so I finished it as quick as I could and forgot to document it. Whoops lol.
I'll have to pull the coil off to shim it anyways, so I'll get pics then.
moregrip likes this.
Sponsored Ad
Register to remove this ad.
__________________
MOD LIST UNDER CONSTRUCTION
BUILD THREAD:http://www.ramforum.com/f17/dubstep_...t_build-55252/
Dubstep Shep is offline   Reply With Quote
Old 12-26-2016, 11:59 PM   #12 (permalink)
scotts2012ram's Avatar
Ram Year: 2012
Engine: 4.7
Default
I wish I could find someone around here that could aline my truck right without wanting 2 to 300. It's only leveled in the rear with 22s if I'm going to pay that much I'll wait and drop it all the way down where I want it then pay that's stupid.
__________________
2012 ram 1500 qc, debaged, leveled rear, full system install alpine hu, skar 5ch. & mono block, jbl doors, sundown e10s in a ported fox box, alarm installed, 5% tint, fuel 22x9.5
scotts2012ram is offline   Reply With Quote
Old 12-27-2016, 05:07 PM   #13 (permalink)
Ram Year: 2016
Engine: Hemi 5.7
Default
only thing in the rear to align is the pinion angle and thrust angle to make sure everything is centered. Do you have any vibrations at all?
__________________
razor1 is offline   Reply With Quote
Old 12-28-2016, 03:15 PM   #14 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Honestly, I just do mine visually. I have a pretty good eye and I'm OCD as hell, so it comes out pretty damn close. Certainly close enough to drive around on for awhile while I mess with things.
Camber is pretty easy to get right. Toe is the most difficult one. Easiest thing to do is get a 2x4 that's long enough to set against the front and back of the front and rear tires. Basically there should be four points of contact, one on the front and rear of the front and rear tires. If the toe is off, then there will only be two or three points where it contancts.
There's also the axle position front to rear and left to right.
__________________
Old 01-03-2017, 08:52 AM   #15 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Pulled my spohn arms apart and cleaned them up, so I'll probably do a write up and add that in sometime this week.
__________________
Old 01-04-2017, 02:25 PM   #16 (permalink)
PassivAggressor's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
Damn. Nice thread. This is interesting as hell.
__________________
'14 RAM 1500 RCSB
PassivAggressor is offline   Reply With Quote
Old 01-04-2017, 03:57 PM   #17 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Sheeeeeet, I haven't even delved into the math yet.
Still working on the Excel sheet for all that.
PassivAggressor likes this.
__________________
Old 01-05-2017, 09:01 AM   #18 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Could you go into detail of the ride quality between the springs?
__________________
'14 RAM 1500 RCSB
Old 01-05-2017, 09:57 AM   #19 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
It's tough to say exactly because I'm running such a bastardized system right now that it isn't really a fair comparison. It's close to a 2/4 drop but I still have stock shocks and I can't get the camber out of the front all the way.
Taking all that into account, it rides really, really well. The front springs are a lot stiffer and I've been pleasantly surprised that the stock shocks have held up so well.
__________________
Old 01-05-2017, 10:54 AM   #20 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Awesome. I had cut a coil off of the stock springs you sent me and a few coils off the rear. It was strange. It rode decently but definitely was stiff. It certainly did not have that bouncy feeling at all.
Sent from my VS990 using Tapatalk
KTMjohn likes this.
__________________
'14 RAM 1500 RCSB
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2016 Ram 2500 Crew Cab lowered with Air Suspension or springs? fatkidbuu Heavy Duty 7 08-11-2016 05:52 PM
Lowered Ram, squeaking suspension N1ck Lowered 18 07-25-2016 12:03 PM
6.4 2500- A different perspective Snyd Heavy Duty 184 02-20-2016 11:25 PM
lowered r/t squeaky suspension 15ramrt Lowered 7 11-20-2015 12:31 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
