Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lowered
Lowered
Lowered Suspension: An Engineering Perspective.
This is a discussion on Lowered Suspension: An Engineering Perspective. within the Lowered forums, part of the 4th Gen : 2009 - Present category!
Originally Posted by PassivAggressor Awesome. I had cut a coil off of the stock springs you sent me and a ...
Like Tree11Likes
Reply
Old 01-05-2017, 11:38 AM   #21 (permalink)
Dubstep Shep's Avatar
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Originally Posted by PassivAggressor View Post
Awesome. I had cut a coil off of the stock springs you sent me and a few coils off the rear. It was strange. It rode decently but definitely was stiff. It certainly did not have that bouncy feeling at all.
Sent from my VS990 using Tapatalk
That's more or less where I'm at now. One full coil off the front and three off the rear. The rear still sits too high, so I ordered a set of Belltech 4" rear coils. I'll try those and see how they are.
I'm also going to compare the Crown 1/2 springs to these.
moregrip likes this.
Sponsored Ad
Register to remove this ad.
__________________
MOD LIST UNDER CONSTRUCTION
BUILD THREAD:http://www.ramforum.com/f17/dubstep_...t_build-55252/
Dubstep Shep is offline   Reply With Quote
Old 01-05-2017, 11:46 AM   #22 (permalink)
PassivAggressor's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
Sweet. I may cut half a coil on the front and the three on the back. I need 20's!
__________________
'14 RAM 1500 RCSB
PassivAggressor is offline   Reply With Quote
Old 01-05-2017, 01:59 PM   #23 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
What're you running on now?
__________________
Old 01-05-2017, 02:23 PM   #24 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Stock R/T suspension.
__________________
'14 RAM 1500 RCSB
Old 01-06-2017, 10:31 AM   #25 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Well that's what I had before I cut them, so yours should sit pretty close to mine.
PassivAggressor likes this.
__________________
Old 01-06-2017, 11:19 AM   #26 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Cool. I don't want mine that low in the front though. So I may just cut half a coil in front. It still seems like you have an inch to inch and a half of rake in the pics. You're running the B/T drop bracket or just the adjustable track bar?
__________________
'14 RAM 1500 RCSB
Old 01-06-2017, 11:49 AM   #27 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Yea, start with half a coil and see what you think. You can always cut off more or add a shim.
And yea, it's still a good inch or two of rake.
No bracket, and I haven't adjusted the bar yet. It actually just sits about right on its own.
__________________
Old 01-06-2017, 02:10 PM   #28 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Here's how mine sat stock:
Here's how it sits now:
Wild one likes this.
__________________
Old 01-18-2017, 12:57 AM   #29 (permalink)
FlynDutchman's Avatar
Ram Year: 2015
Engine: Hemi 5.7L
Default
If you still have issues with the truck not sitting close to level on the left and right side. Loosen all the bolts on the rear upper and lower arms and the pan hard bar. Drive the vehicle slowly in your neighborhood and than on level ground retighten (torque to factory spec) the upper arms, lower arms and pan hard bar with the wheels on the ground. Recheck your measurements and hopefully this helps.
DERJ and Wild one like this.
__________________
Martin
2015 Ram Sport CC 2wd
Tint, DeBadged, Magnaflow, Plasticoat Wheels, painted calipers, Bullet liner
FlynDutchman is offline   Reply With Quote
Old 01-23-2017, 10:19 AM   #30 (permalink)
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
Yea I made sure not to tighten down the control arms until the suspension was settled. That's not the issue, it's just that the drivers side is a lot heavier on these trucks thanks to the fuel tank.
For those that don't understand why this needs to be done, it's because factory rubber bushings are preloaded to a set ride height. Rubber bushings twist as the control arms move up and down, and as such they act like a spring. That's why you can't just turn a rubber bushing control arm as it sits. With poly, delrin, or metal, the joint slides rather than twists.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2016 Ram 2500 Crew Cab lowered with Air Suspension or springs? fatkidbuu Heavy Duty 7 08-11-2016 05:52 PM
Lowered Ram, squeaking suspension N1ck Lowered 18 07-25-2016 12:03 PM
6.4 2500- A different perspective Snyd Heavy Duty 184 02-20-2016 11:25 PM
lowered r/t squeaky suspension 15ramrt Lowered 7 11-20-2015 12:31 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
