McGaughys 2" Lowering Springs- Shock Upgrade?
TRXHemi
Sugar Land, TX
No sag in mine actually. That pic was kind of on a small incline!
No axle issues, no wobble issues with the 2". Everything is perfect.
AzCats
Portland OR
2014 1500 CC Laramie
I have the McGaughy's 2" drop rear springs on my 2012 Ram CC. Recently installed front and rear Bilstein 4600 shocks. I like the ride much better than oem shocks.
Eddi310
San Antonio (Kirby), Texas
2010 Lone Star
Man I'm slacking, i need to install my 4600s. I have the McGaughy's 2" drop springs too on my 2010 CC. Did the overall height of your truck change after installing the 4600s? All i want is a better ride haha i dont want my truck to be any higher...
AzCats
Portland OR
The ride height stayed the same with the 4600's. IMO it rides better and is more planted. Still comfortable.
Make sure you have a 21mm Crowfoot wrench for the rear shocks top bolt/nut. I made the mistake of taking everything apart and couldn't get that top shock bolt off and had to order a 21mm Crowfoot wrench on amazon.
Eddi310
2010 Lone Star
I was changing my brakes over the weekend and i saw how it was impossible to fit a wrench in there haha i was thinking about cutting one in half. I didnt even know about that crowfoot wrench...Ima get on of those instead. Thanks for that info bud
Storm Trooper
i removed the lower shock bolts to install my MGs. worked great.
VB712
Maxi_built
Va Beach
I have the same setup on my 4x4. I really want to install the 4600s on mine. How hard was the install for the front? I feel like the factory shocks on the front ride like crap.
AzCats
Portland OR
Sorry my truck is 2wd so it was only 3 bolts total but the 4x4 install doesn't seem too bad after watching youtube of the process. Def need a spring compressor for the front shocks/springs for 4x4. Good luck
