gr8ridn
I have decided to go with the McG Deluxe Kit.
My question to those who have done this install is what method was used to separate the ball joint studs and tie rod from the original spindle?
I was thinking penetrant soaking and striking the spindle with a hammer to loosen the taper fit. I would use heat if it became necessary (heat gun).
I keep hearing about ball joint separator tools but hope that isn't necessary. Don't want to use the pickle fork and damage the boots.
Thanks for any tips you learned from this job.
