Need some lowering recommendations
mpress2570
Since I like to be different than the average and my truck doesn't even know what dirt is I am going to be lowering it and throwing on some hellcat replica wheels and a ducktail spoiler on the tailgate. I need some advice though. Should I lower 2 inches in the back, or 1 inch up front and 3 in the back?
Also I could use some lowering kit recommendations, and would also like to know how much I'll be compromising my ride quality, if at all. Thank you in advance.
ramportin1
Sickest member here
Oregon
Since I like to be different that the average and my truck doesn't even know what dirt is I am going to be lowering it and throwing on some hellcat replica wheels and a ducktail spoiler on the tailgate. I need some advice though. Should I lower 2 inches in the back, or 1 inch up front and 3 in the back?
I love the duck bill spoiler honestly, I almost thought about putting it on mine until I realized I could no long throw my dirt bike ramps on my gate lol. Multiple people on here with excellent lowering knowledge so you'll be set
ramportin1
Sickest member here
Oregon
O, it's you! Lol
ramportin1
Sickest member here
Oregon
It's me? Lol
Errrr Maybe I'm mistaken idk I'm using tapatalk lol but aren't you the guy that was posting in the "LED VS HID" thread and I commented on you having a sick ram. Maybe I'm wrong, if so my bad
mpress2570
mpress2570
Oh yeah. It's me haha.
ramportin1
Sickest member here
Oregon
Lol
ramportin1
Sickest member here
Oregon
Bump
mpress2570
mpress2570
Best method for lowering
I want to lower my 17 1500 CC. I was wondering what the best method is to do it without hurting the geometry or ride quality. I'm not exactly sure how low I should go. My 3 options are: 2 inches in the back, 1 inch up front 3 inches in the back, or 2 inches up front 4 in the back. I want to achieve a sporty look but again not compromise ride quality or geometry. I would appreciate any help from those knowledgeable. I was thinking drop spindles or lower control arms.
Wild one
14 Sport
As soon as you lower it,you're screwing up the geometery.There's multiple threads on lowering the trucks,so you might want to start looking through threads,and maybe you'll get the answer you're looking for,as your question is very vague.Decide how low you want to go ,and work from there when you're searching through the threads on here.
Quicksilver337
South FL
2016 Ram R/T
I agree..
and to add to this don't lower it if you want to keep the same ride quality as stock.
Lowering will make the ride stiffer... as for geometry, if go 4" or lower in the rear you need to install a re-location brackets be it from Inez hotrods or Illicit customs. Illicit is the only one that has the "no cut" brackets.
Inez Hot rods make a 4/6 or 5/7 lowering kit if you want to go that route .
Inez Hotrods
Illicit Customs
mpress2570
mpress2570
Even with drop spindles? Everything stays the same you're just moving the wheels up. I'm just wondering how low I can go before I start messing up ball joints and crap.
mpress2570
mpress2570
I agree..
Inez Hotrods
Illicit Customs
How bad would it be do you think to just drop two inches in the back to level it off?
Wild one
14 Sport
Dropped spindles won't screw up the front,but as soon as you drop the rear you screw up it's geometery.You can do a 3" front drop easily with a set of spindles and a 1" drop spring,and it should still wheel align.On the rear 2" will be okay,but if you go 4" you might run into either bad wheelhop or a high speed sway.Some trucks get away with a 4" rear drop with-out any issues,but a lot of trucks will exhibit either hop or sway,it seems to be more luck of the draw.If you end up with either issue on the rear,you'll want to look into either Illicits or Inez's relocation brackets.I recommend the Illicit versions,as some guys are reporting issues with the Inez relocation brackets.
mpress2570
mpress2570
Well I appreciate the help. I'll keep digging further into it, but if there's an risk at all I likely won't do anything hurt anything on a 50k dollar truck so I'm pretty certain I'll be just dropping 2 in the rear only
BAMF
Southern Louisiana
2015 Big Horn
I think that's what I want to, but then need airbags because I tow quite a bit
