I have a 2013 Black Express RCSB with a 2/4 McG drop with Bilstein HDs.
Currently running the factory Goodyear 275-60/20 on the factory rims but the tires need to be replaced.
Going to get the Goodrich KO2s and here is the question:
The 275-60 is 32.9" tall
The 275-65 is 34.0" tall
The 285-65 is 34.5" tall
Frankly, I'd like to go to the 285-65, but I'm guessing that's not gonna clear in the front with the 2" drop. I'm sure the back will be fine even with the 4" drop.
What I was thinking was putting the OEM front springs only in to run the 285-65s. Good idea? Bad? I really don't want to go back to stock ride height.
Failing this, suggestions? Think the 275-65s will clear fine?
Thanks
Thanks
