OK - as per Tim at QA1, he stated he could get us the correct shock for this application is someone is willing to get:
Shock length at ride height and the diameter of the shocks mounts
Anyone lowered trucks care to do some legwork for the team? lol
This is everything they would need to know. The lengths of the shocks below are right for your purpose. This is exactly the parts the went on my truck:
Summit
(2) - QA1 TS507 Front shocks
(2) - QA1 TS801 Rear shocks
(2) - QA1 9032-102 Bushings (for the rear shocks)
http://www.summitracing.com/
WFO Concepts
(4) - 4261 Metal sleeves, OD of 3/4", ID to fit 9/16" bolt (you must request they be cut to 1.25" if you are going to use spacers/washers like I did)
4x4 Custom Truck Parts | Off Road Truck Parts | California Custom Trucks
Amazon (or local hardware store)
(8) - Spacers for 9/16" Bolt Size, 19/32" ID x 1-3/16" OD, 3/16" Thick (I used 16 heavy duty galvanized washers)
Morton TW-5SS Stainless Steel 300 Heavy Duty Washer, 9/16" Bolt Size, 19/32" ID x 1-3/16" OD, 3/16" Thick (Pack of 10): Amazon.com: Industrial & Scientific
If you want to get new shock nuts and bolts:
AllMoparParts
(4) - BOLT-HEX FLANGE HEAD, Part#: 6502818 $3.47ea
(4) - NUT-HEX FLANGE LOCK, Part#: 6502698 $2.86ea
These are available to order here using the part number search:
Repair Parts
