I have the hellwig rear sway bar installed with a 5 inch rear drop, im using the McGaughys shorter rear links but those are really intended for a 4 inch drop. I have the Inez kit on order and plan on going to a 6 or maybe 7 inch rear drop and am wondering should the rear sway bar be ideally parallel to the ground, tip pointing up slightly or down slightly? I don't know enough about the geometry and what effect each option would have. I dont mind changing the links I just dont know what angle I should be using. Any experts or someone who can point me to a knowledge base?
