SPC Adjustable Ball Joint
Quicksilver337
South FL
2016 Ram R/T
Quicksilver337
Quicksilver337
South FL
2016 Ram R/T
Does anybody see a benefit in this, I mean if you can get the front suspension geometry back into spec with this adjustable ball joint. I think it would be great to use it or not :shrug:
R/T_Fire
Pleasant Grove
My tire/alignment guy recommended them for me since mine are so far out of whack... I think they were .65 degrees....
but the ones he showed me were up to 3 degrees.... I'll see if I can find the part# Ive never done it cause the cost isn't worth it to me with other things I plan to change. they were $150 each.
R/T_Fire
Pleasant Grove
They might be the them, I just remember them being 3 degrees but I may be wrong.... I posed them on here about a year ago but cant find the pic of the part catalog he had... I'll find it but I think if you need to fix the camber its worth it. I want to get rid of the stamped A-arms and in doing that I was going to lengthen the arm to make up for there the balljoint falls short for proper alighment
Quicksilver337
Quicksilver337
South FL
2016 Ram R/T
I think I found it, it's made by Moog. Moog states on their website that it's only made to fit up to 2013. I sent them an email to see if it'll fit on 2013-2016. Your right it is adjustable up to 3 deg + camber
Moog part# K100115
